- 31 Dec 2012
hi all
could somebody recommend me a graphics card please. i havent currently got a graphics card in my system im using the onboard HD4250 and as it currently meets my requirements i never bothered getting an independent card.
my budget is around 150, i would like to stay as close to this as possible and under is always better.
my current system is
board ASUS M4A88TD-M EVO / USB3
CPU AMD Phenom II X6 1055T
psu Anteq Basiq 550 Modular
Ram 4GB 1600mhz DDR3
2 x 1TB sata hard drives
1 x 2TB sata hard drive
1 x DVDRW
its used mainly as a media center and general surfing as its connected to my TV so will need HDMI out, i wouldnt mind being able to play a few games on it thats why i decided to get a graphics card in the first place. i dont need one that will run games on highest resolutions because my TV support is 1280 x 720p only
only reason im asking on here is that in the good old days a graphics card was better if the model was higher, nowadays im not too sure.
like is it better to have a higher core value or memory speed, is 2GB always better than 1GB, then what difference would stream processors make.
ie which is best
1 Core: 900MHz, Memory: 1024MB 4800MHz GDDR5, Stream Processors: 1024, or
2 Core: 1100MHz, Memory: 1024MB 5200MHz GDDR5, Stream Processors: 640,
number 1 is 131.99 and number 2 is 119.99
anyways thanks for reading and hope someone can shed some light on it for me
also if i could do with a bit more ram which should i get, im running W7 64bit
thanks craig
1 x DVDRW
ie which is best
thanks craig
