Recommend me a Conroe CPU Waterblock
18 Oct 2002
NW London
Hi,
I'm putting together a Conroe based system as follows:
E6300
Gigabyte QS3
I'll be watercooling this and need recommendations on which waterblock to buy. Looks are not important. Functionality (ie. low temps) are important.
I already have the Swiftech MCW6002 S478 block, but this wont fit on the LGA775 socket of the Gigabyte motherboard.
Thanks
Alphacool NexXxoS XP.
Might have to look around a bit for the LGA775 Mounting bracket version, but they are available with a quick google. :)
The alphaextreme is very expensive (£48 inc del).
The Nexxxos is comparatively cheap (£28 inc del).
Is there really that much of a performance gap between the two blocks?
The Nexxxos is one of the best blocks you can buy, but you're only likely to be speaking about a few degrees difference between most of them.
Jokester
