Recommend me a cooler - pretty please
11 Oct 2004
Buckley, North Wales.
Order a few new components yesterday, have a feeling its not getting delivered tomorrow :(
I5 4670k
Z87 D3HP
Avexir Core Red Series 8GB 1600MHz Dual Channel Memory Kit
K2 mount doom
Order says it's in the queue and the mount doom is out of stock. Typical
Won't know for sure until I ring tomorrow morning
So I need a replacement specced just in case, I will be overclocking it.
Its all going in a Akasa Eclipse62
Any ideas
Cheers
Craig
Can't see your case at OCuk, but you can check Prolimatech Megahalems, needs 159mm clearance to side panel. It uses 120 or 140 sized fans, but 120 are recommended due to ram height. I have my megahalems with 2 akasa apache black, 800 rpm and very quiet. My cpu is i7 4770k, temos 25 idle / 45 under load. My ram is also avexir so you should be ok.
Its an old case, not available anymore.
Will have a look at the megahalems.
Case
Akasa Eclipse62
Had about 1mm clearance on the tips of the heat pipes sliding the tray into the case, fans had to be fitted afterwards, probably about 5mm clearance between the top and the side panel
No rattles or vibrations, its so quiet
Sorry, I don't understand. Silver Arrow SB-E is not clearing case, but you have 1mm clearance on heatpipe tips when sliding in tray and 5mm between top of cooler / fans and side panel. So where is the "just about fits"?
Good cooler. Have the Extreme model myself.. received new Silver Arrow IB-E Extreme today! :D
Think you're confused, its in the case but only just.
Wasn't asking for help.
