- 8 Mar 2013
- Chiang Mai
K well here's my situation, I'm using an artic freezer 13 that can only be mounted pushing air out the top of the case because I'm running amd and using standard mounting. I'm going to be adding a 7870 xt (using 7770 now)to my set up and I'm expecting that the temps in my case are going to increase dramatically
my case has 3x 120mm fans (front) 120mm + 90mm (back) 90mm (top) so air flows not that bad and can be improved with better case fans but right now the flows all over the place with the cpu fan pulling from the gpu and pushing out the top.
So I'm looking to grab a cooler that can be mounted facing any direction and that will push a decent amount of air. have low profile ram so most large coolers aren't a problem. I'm not that concerned by noise either as the 7870xt will be making a fair bit of it.
I hear the k2 mount doom is good and so's the silver arrow/be quiet dark rocks but are there others coolers I should consider and should I use the fans that come with these coolers etc and are they all capable of being mounted in any direction on a amd 990fx sabertooth mobo.
or alternativly should I just get one of these http://www.overclockers.co.uk/showproduct.php?prodid=HS-022-CS and wait 5-6 weeks and put some better fans on it for around the same cost of a big air cooler? I used to watercool before and not a fan of the all in 1 loops but at such a low price it's pretty tempting
