Recommend me a decent quality zoom lense for a Canon 650D?
3 Apr 2007
Land of the sheep
Was looking for tack sharp images of long distance landscapes, buildings aerial masts etc...was considering the following:
Canon-70-200mm-4-0-USM-Lens
Sigma-70-200mm f2.8
Tamron SP AF 70-300 F/4-5.6 Di VC
Noob question: Will these offer a substantial leap in image quality over the bundles kit lenses ?
Thanks
Sigma will be faster (F/2.8) obviously, and would be my choice, however, you may still find yourself short in length, go and try one first. Answer to your 2nd question, hell yes! You pay a premium for good reason :)
If you want true tack sharp maybe consider a long prime. I have the Canon 70-200 IS II f/2.8 and it's very sharp and a great portrait lens, but not as sharp as a prime.
A lens with f2.8 is a trade-off: higher prices and softer images when shot at 2.8, in exchange for the versatility to handle a wider range of shooting conditions. If you're chasing maximum sharpness, a fair rule of thumb is to use somewhere around f8 (some lenses are sharpest slightly above or slightly below that, and it depends on camera body too). And then if you are aiming for f8, it does negate the value of an f2.8 lens to some extent.
Sometimes an even bigger problem for long-distance sharpness can be the atmospheric conditions, no matter what lens you're using. Post-processing helps a little there for some kinds of haze, but heat-distortion can throw all kinds of bulges and ripples into a distant mast that are not simple to correct.
Of the lenses you mentioned, the Canon seems to be well regarded for sharpness, and might give you enough of an improvement to be noticeable over your current lens. A quick search for samples from the others shows they can suffer more from chromatic aberration and corner softness.
As Scurra says, the f2.8 (II) version of the Canon is ridiculously sharp, and I've read a few reviews in the past that say the f4 lens is almost as sharp. The problem with picking a single prime for shooting distant buildings, etc. is that you might not have enough leeway with your vantage point to be able to move around and get the framing you want, so personally I'd go for a zoom (or a selection of primes, of course!).
I'd point out that telephotos aren't really the ideal lenses to use for landscape photography.
If shooting landscapes, then ideally you want to be using a wider angle lens and get as close to your subject as possible to retain sharpness.
Obviously a telephoto has its uses for capturing details of a landscape or a structure, but as pointed out above, if you are using it simply to capture say a spire that is miles away, you are still looking at a fairly compromised image that is going to be less sharp compared to getting closer to it.
With everything as a stationary object I'm not certain you need to pay the premium for a fast lens.
I have seem a few Canon EF 300mm f/4L USM NON-IS lenses go for not too silly money second hand. Depends what kind of long distance landscapes you want, particularly taking into account its on a crop camera.
