I am having some issues with my Bulldog line sync dropping using either my internal PCI modem or my USB Speedtouch modem. This is becoming increasingly annoying as the connection then wont work until I disconnect and re-connect (which potentially stops any torrent files downloading overnight, 10 minutes after I've gone to bed!!)
It makes no difference setting it to re-dial because its not the connection thats gone, just the line sync!!
Anyway, I've been told that a router would probably improve the stability of the line sync, my question is....which one is best (while not beeing too expensive)
I've been looking at the Belkin 7633, as it supports ADSL2+, which I'm told Bulldog will shortly be upgrading people to!!
Anyone got any opinions on this or any other router to suit my needs??
Many thanks
StevieP
Many thanks
StevieP
