Recommend me a Full Tower Case
18 Oct 2002
Cambridge, UK
Hi,
Haven't bought a new case in about 6 years and my old one (which I can't even remember the make of) is now looking very tatty (but still fuctional), I would like a new full tower case that can take as many 5.25 devices as possible!
Looks aren't hugely important, cool and quiet are as it's going to house my new Conroe and 8800GTX rig as well as multiple hard drives as I need the space (RAID).
Thanks
HEADRAT
Any of the Lian-Li V2000xx / V2100 / PC-201 / etc.
Space for 12 Hdd's in the base, a possible 6 other HDD's in the 5.25 bays and will easily fit one/two 8800GTX's. :)
Loads of space.
Lian Li 343 if you did actually mean 5.25, if you meant 3.5 then the v2000+ would probably be more economical as you won't need adapters.
HEADRAT said:
Yeah I think 18 is overkill, I know I said as many as possible but 18 is a little OTT!
HEADRAT
you sure? 18 drives using a decent RAID card would be bang on the money! :)
