Recommend me a game for a low spec laptop!
30 Sep 2003
Norwich
Ok so new position at works means I've now got a (cheap) laptop. As fun as surfing the net is I think I need a game or 2 to keep me entertained when I should be working... er I mean on the train between meetings... or something :p
As I say its a cheapy Acer, bottom spec but I'm sure theres something out there to keep me entertained even if it is a year or 2 old.
Nothing that requires accurate mouse control (FPS etc) as I'm a bit rubbish on the old touch pad :o
I was thinking Champ Manager but I think it might go into meltdown.
What do you recommend?
Diablo2. If you can find a mate to play co-op with you'll have countless hours of hacking, slashing and looting :)
Pro Evolution 5 works on my dads laptop nicely. 'Tis a 2yr old Acer. I did put an extra 256MB of RAM in there though,
MC_Bob
Some good suggestions guys, found my worms 2 CD when looking for my PDA software so thats going on tonight, also plenty of others to have a look at.
*goes to google uplink*
