Hi everyone, id thought id ask you folks on here about recommending a graphics card for my stsem, its not an amazing machine but fairly decent and i was wanting to upgrade my graphics card to something a bit more powerful
i currently have :
AMD 64 3000 2ghz
1gb ram
My motherboard does not have pci e slots as my current card is a 6600gt agp card, so i know this limits the options now as most people are on the newer pci-e motherboards
Any help would be great or if theres any more info needed just ask
thanks
i currently have :
AMD 64 3000 2ghz
1gb ram
thanks
. If it was me then I'd keep my eye out for a dual core CPU and overclock it a little to help that X1950Pro. Don't worry too much about it though, it's just a little pointer if you start to experience less FPS/points than you are seeing in benchmarks. It will most likely be down to being CPU bound.
