The performance can be tailored to your needs by using the variable fan speed adjustments on the VR fans. You can set a low 1200 RPM setting for a low noise, yet still cool running CPU, or you can go all-out with the maximum 2500RPM setting for all-out performance
They have variable resistors so you can change the fan speeds. On low, the fans are quiet.
i would listen to Helios, when it comes to coolers, he is very knowledgeable.
i bought a used Noctua NH-D14 for £40, so if you dont mind buying used, have a look around and see what you can get![]()
just check the overall heights of the coolers, a lot won't fit in an asgard, it is a narrow case...
