I have had enough of this Akasa. Only had it a week and hate the looks. I much prefered the original Eclipse though that was not a pretty picture either.
So I want a high end case that cools as well as the Akasa or close to. Would prefer no door, but if I have to compromise so be it. Budget up to 250 quid, so almost anything is open. Ruled out the Lian Li V2000 cause I don't like the looks. I want to be able to run this case with quiet fans and the cheesegrater doesn't help.
What I have shortlisted
1. Original stacker..can get them very cheap locally (about 80 sterling). Would add an additional 4in1 drive for extra cooling, replace the noisy top 80mm fan. Looks are ok I suppose, better then Akasa, but concerned over the issues people were having getting their pci cards to sit right.
2. Lian Li A10...everything about this I like except the door and the fact I could be left with an empty psu bay, so crap gets into the case.
3. Silverstone Tj07 - now we are talking. No door. Clean smooth looks. I know the Tj07 had some complaints about poor gpu cooling which is easily solved with a Scythe Katana in the front. And I know the fans are not the quietest on the Silverstone - also easily solved as I have tonnes of quiet fans. And also have some extenders for the psu's to reach the 12v connector on the mobo, so that is not a problem. 2 things that concern me are whether I will be able to fit my 120mm fan on my Ninja so it is blowing air into the case as I know the rear fans blow in on the TJ07. Also, lots of complaints about sticking panels, and mobo standoffs not screwing in right, and scratching when taking side panel off. Supposed to be fixed with Rev 2.
So any suggestions ?
