Recommend me a monitor?
14 Aug 2017
Looking for a new monitor, 28"+, freesync.
Main reason to post a query, running one vega 64 which is more suited to 1440p than 4k, but I would like to get a 4k monitor. Don't need anything more than 60hz.
Monitors I've used in the past don't look good when not using their native resolution, wondering if any 4k monitors out there which do 1440p which looks normal?
Normally monitors don't like to upscale. However Samsung are using QDOT in their monitors which resemble their TV line, which in turn have brilliant upscaling built in.
I'd suggest looking into their 4K QDOT HDR Freesync monitors for an ideal solution. That's what I'd buy if I were you anyways.
You've made the odd decision to go Vega64, but at least you have some great Samsung monitors to choose from!
Just type in HDR into OCuk search box within their store and a list of nice Samsung monitors appear.
