Recommend me a new monitor, around 32 inch.
12 Jul 2012
I'm after a new monitor to replace my 27 inch Asus which has been great, ideally the new one to be around 32 inch which i think would be a good upgrade from 27 inch. The main use for the monitor will be watching movies and things like youtube, prime video etc etc, i will still use it as a PC screen as it's located in my bedroom hence why i want it be be good for watching things as well as doing some light computing on it, i won't be doing any gaming. My current GPU is getting on a bit now, it's a Sapphire AMD Radeon R9 290X Vapor-X Tri-X GDDR5.
I'm open to suggestions so go for it, thanks.
Selecting exclusively from OCUK to support them, we have:
Iiyama 32" GB3271QSU-B1 2560x1440 IPS 165Hz 1ms FreeSync Premium Widescreen LED Backlit Gaming Monitor £319.99
MSI 32" G321Q 2560x1440 IPS 170Hz 1ms FreeSync/G-Sync Gaming Monitor £338.99
LG 32" 32GP850-B 2560x1440 NANO IPS 165Hz 1ms FreeSync/G-Sync Compatible Widescreen Gaming Monitor £348.95
For your use case though, as you aren't gaming, it could be argued these are overspecced as you don't need the high refresh rate. I am also selecting IPS in preference to VA for rich colours and wide viewing angles. OCUK only has 2560x1440 IPS screens, but it could be argued you only need 1080p for your use case.
