Recommend me a PSP 3003 SD CARD
26 Mar 2010
London
I'm not sure the limit in size or types of sd cards the psp accepts, so I hope you experts can recommend me one. I think a 16gb would be suitable that's if the psp accepts that size.
Thanks
The only option you have is the proprietary Memory Stick Pro Duo.
Either a Sony or Sandisk one will be fine, but watch out when buying them, as there are fakes. Be especially suspicious of makes other than Sony or Sandisk.
You can get a 16gb one without a problem. They come in many sizes. I believe the PSP can accept cards up to 128gb.
You can get adapter cards which hold two micro SD cards. The adapter just goes in the PSP like the proprietary cards.
This, it's far far cheaper to do this than get a memory stick pro duo.
