Hello,
Would you be able to recommend any good and quiet PSU to run smoothly with:
I'm looking at Corsair HX1000i but not stock anywhere , so maybe HX1000 ...?
Unfortunately , I'm unable to get any graphic card at this point.
Many Thanks in advance.
- AMD Ryzen 7 5800X Processor (8C/16T, 36MB Cache, Up to 4.7 GHz Max Boost
- MSI MAG X570 Tomahawk Wifi Arsenal Motherboard (AMD X570, 2x PCI-E 4.0 x16, RAID 0, 1, 10, Intel Wi-Fi 6 AX200, Bluetooth 5.0)
- Cooler Master MasterLiquid ML360R RGB CPU Liquid Cooler - ARGB Lighting Sync, Premium Pump Design and Tri MF120R ARGB Fans
- Corsair Vengeance RGB PRO 32GB (2 x 16GB) DDR4 3600MHz C18, High Performance Desktop Memory Kit (AMD Optimised) - Black
- Cooler Master MasterCase H500M ARGB - PC Case with Dual 200mm Fans for High-Volume Airflow, 4 Tempered-Glass Chassis Panels, Advanced Support
- Cooler Master MasterFan MF140R ARGB 140mm Addressable RGB Fan - Riffle Bearing, Hybrid Air Balance Fan Blade Design, and Jam Sensor Protection
- Seagate BarraCuda 2 TB Internal Hard Drive HDD ? 3.5 Inch SATA 6 Gb/s 7200 RPM 256 MB Cache 3.5 Inch ? Frustration Packaging (ST2000DM008)
- Samsung 970 EVO Plus 1TB M.2 2280 NVMe PCIe SSD 1TB Capacity MZ-V7S1T0BW
- Monitor LG LG 27GL850 27'' UltraGear™ Nano IPS 1ms
