21 Dec 2006 at 09:15 #1 cmscam cmscam Permabanned Joined 24 Oct 2006 Posts 108 Hello guys. I hope this is in the correct forums. Please can you recommend me a PSU (from OcUK of course) for around £30. The PSU will be running a 7600GT GFx card and an Intel Pentium 4 - 3.00GHz. 1GB Ram, 160GB HDD.! Thanks!! Last edited: 21 Dec 2006
21 Dec 2006 at 09:19 #2 Raikiri Raikiri Soldato Joined 5 Jul 2005 Posts 17,995 Location Brighton http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-SK
21 Dec 2006 at 15:34 #3 cmscam cmscam Permabanned OP Joined 24 Oct 2006 Posts 108 I was told by a guy @ the OcUK shop to get this one : http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-TG But do you think the one you posted in your thread will be good enough ? Thanks.
21 Dec 2006 at 16:32 #4 psumann psumann Associate Joined 28 Sep 2006 Posts 72 http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-CS Better efficiency, noise level, price, and warranty than the Tagan
21 Dec 2006 at 18:32 #5 Defcon5 Defcon5 Soldato Joined 4 Sep 2005 Posts 6,424 Location Whitwood, West Yorks Raikiri said: http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-SK Click to expand... Save your cash and get this one
21 Dec 2006 at 20:54 #6 cmscam cmscam Permabanned OP Joined 24 Oct 2006 Posts 108 Defcon5 said: Save your cash and get this one Click to expand... So you think that that PSU will defo run my pc / graphics card. Thanks
21 Dec 2006 at 22:05 #7 Defcon5 Defcon5 Soldato Joined 4 Sep 2005 Posts 6,424 Location Whitwood, West Yorks Thats the one id buy for sure
21 Dec 2006 at 22:18 #8 cmscam cmscam Permabanned OP Joined 24 Oct 2006 Posts 108 Defcon5 said: Thats the one id buy for sure Click to expand... Cheers mate. I'm going to get that one you said. Any one elses opinion would be welcomed. Last edited: 21 Dec 2006
22 Dec 2006 at 01:12 #9 t31os t31os Soldato Joined 24 May 2006 Posts 3,824 Location Surrey - UK Raikiri said: http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-SK Click to expand... Would be fine.
22 Dec 2006 at 10:12 #10 Trusty Trusty Soldato Joined 12 Mar 2006 Posts 17,806 Location Boarding the Nostromo yeh go for that one, £30 too. Not much really!
22 Dec 2006 at 12:24 #11 cmscam cmscam Permabanned OP Joined 24 Oct 2006 Posts 108 Yeah, that's the one for sure I'm getting ! Going to nip down later and get that one.
