My HX850+ is starting to show its age now, I applied an overclock on my GPU and after about 20 mins the PC switched off. Removing the overclock stopped this happening. PSU is probably 8-10 years old now so I think its time to get a replacement.
What would you suggest for 5900x & 6900xt? Happy to go to about £200 for a decent unit.
I have been looking at the following but unsure if a 1kw might be a better solution - or it might just be the age of my current one which is making me think 1kw would be better.
https://www.overclockers.co.k/corsa...lar-power-supply-cp-9020196-uk-ca-24t-cs.html
https://www.overclockers.co.uk/phan...old-modular-power-combo-supply-ca-08a-pt.html
https://www.overclockers.co.uk/seas...-platinum-modular-power-supply-ca-05w-ss.html
