squiffy said:The SS 430W lacks PCI-E graphics connectors, so if you don't want to use Molex to PCI-E, get another PSU. Do you want SLI GFX power outputs also?
Enermax EG465AX-VE(G)(FMA) 460W ATX1.3 Power Supply (CA-004-EN)
Enermax''s new improved 460W PSU that meets ATX 2.1 & ATX +12V 1.2 Version. Pentium 4 supported! AMD Desirable Mechanical Version with Gold plated connectors to provide perfect conduction. Dual fan design of E type PSU and all with thermal control function. Cable tube tied design for neatness. This latest edition allows for manual speed control of the PSU''s exhaust fan via the installed Rheostat and is an Active PFC Switching power supply. On low speed this is a noiseless solution PSU.
Note: Updated revision now supplied with copper shielding and SATA power connector along with 20-24 pin power converter
if im right, this psu should be compatible with newer motherboards too (am2/conroe etc)..
Mr Singh said:anymore suggestions?![]()
how about this one?
the only difference between atx 1.3 and atx2 is the power connector isn't it?if im right, this psu should be compatible with newer motherboards too (am2/conroe etc)..
thanks![]()
Stelly said:I dont think that ATX 1.3 and ATX 2 will not run newer motherboards... and I also wouldnt run Conroe or AM2 on a 420w PSU
Stelly
Mr Singh said:argh, i would go for the seasonic as you recommended but i would like future compatibility with newer chips as well![]()
