Recommend me a Psu
8 Feb 2004
North West
Hi all im upgrading to Duo 2 conroe soon so need a good PSU that can handle this spec:
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB) (MY-108-CS)
Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail
Thermaltake VC3000SWA Armour Jr SuperMidi Tower - Silver
I also want the PSU to be modular as well
Any recommendations? :) :)
Corsair HX620W [Made by Seasonic]. Or the HX520W, if Crossfire is never going to figure in your plans.
I'd get the enermax liberty 620W.
Nice and quiet for a start, plus you choose how many molexes and connectors you have coming out of it, helps keep the case a bit tidyer.
You should change to graphics card to:
HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail
Its a little bit more expensive, but the ICEQ 3 cooler is meant to be very quiet. Especially compared to the very noisy stock coolers the 1900 cards come with.
Hi all Will the enermax 620 be able to handle crossfire in the future since il buy another x1900 6 months down the line?
Just want to make sure. :)
