Recommend me a PSU.
20 May 2007
Stoke-on-Trent
Hi,
I need a new PSU after mine went bang,
I have been thinking about the 3 below but would
like your recommendations.
I want one with over 600Watts, it has to be silent, modular and of course reliable.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-036-BQ&groupid=701&catid=123&subcat=1083
http://www.overclockers.co.uk/showproduct.php?prodid=CA-021-BQ&groupid=701&catid=123&subcat=1083
http://www.overclockers.co.uk/showproduct.php?prodid=CA-022-CS&groupid=701&catid=123&subcat=1084
Thanks.
I have the Dark Power Pro 650w in my pc right now and it is nice and quiet. You can aslo hook 3 pin case fans straight into the 4 dedicated sockets.
Good choices very hard to choose, I would go with the New BeQuiet PSU then the Corsair, don't ask why :p
Looking at your sig, my Enermax Liberty failed after 14 months use.
i would pick this one! Be Quiet! Dark Power Pro 650W ATX2.2 Modular SLi Compliant Power Supply
Between them all there's not much. All modular, all around the same wattage, all good enough efficiency. Nothing wrong with any of them, so i'd have gone with the cheapest (Corsair) but i don't have any noise figures. Never heard a bad word said about them though.
