recommend me a rad
23 Jun 2004
Blackburn
I currently have a XSPC triple fan rad in my water loop sat outside of my case. In gonna be giving all my block a good clean at some point this week and was thinking of changing the rad for a dual 120 fan one at the same time as i would then be able to place it inside my case.
Other components in the loop are a DD TDX, DD Maze4 gpu and Hydor L30 pump (probly gonna be getting changed for a Laing D5) and they are cooling a Opteron 170 and a x1900xtx
So is there a dual 120 fan rad out there that can give similar performance to my current rad?? have been looking at thermochill rads, are they worth the extra? What rad would you guys recommend?
Thanks
As said the PA's are the best rads available, but they are large compared to other makes. if your stuck for space internally then there is also BIXII very small, and the new stealth GT super small but louder as the fins are more dense
nah space aint a problem if i get a 120.2 rad. so looks like a thermochill then. but how much of a performance drop am i likely to see going from a 120.3 xspc to a 120.2 pa thermochill??
