Recommend Me A Router
18 Oct 2002
Ammanford, Wales, UK.
I've had my trusty Netgear DG814 for ages, and in fairness its been faultless.
However, im looking for a new one, nothing too flash or expensive.
Would require Port forwarding, and also show my line status, ie attenuation, noise levels etc.
Im on ADSL by the way.
Four ports or more please, and something reliable that doesnt need reboots every day :)
Thanks in advance.
Fair enough lads.
Might aswell stick with Netgear, not had any trouble with this one.
Ive just bought it, should be here on Wednesday for the pricely sum of £35 :)
This might be silly question but if its trusty and daultless why do you want another router?
The only reason is that i want a router that will give me line stats :)
And it was cheap enough :)
Ahh fair enough, I vote for the DG834G but not the GT version as there seems a fair few problems with it
WAG54G is good.
The old '54g' was a bit shaky, depending on the revision you got.
But the '354g' is a very good product.
