lolThe Deuce said:I have no preference but i do think the netgear is pretty ugly![]()
thought the same till i sow one in the flesh, especially the 'iPod' white ones.
Its for Cable broadband though can work with an ADSL modem
mike1210 said:As above the 877W great if you have a decent knowledge of networks, but they are not cheap and IOS upgrades are not free either.Im sure the IOS it comes with (think it's 12.3.8) isn't the best either. Draytek are also great and don't cost as much (around £150). Really depends on how much you want to spend
<snip>
take a look there![]()
Burbleflop said:FWIW, my 877 came with 12.4.6.T. You don't need to even touch the command line to get an 877 up and running - the SDM will do it all for you. I'm not a fan of SDM at all, but it does seem to work a lot better than it used to.
Personally I wouldn't bother with Draytek as they seem to be very good at writing a feature list, and less good at making the features actually work.
But yes, it does depend on price, but since the OP didn't give any indication, I'd still recommend the 877W.
