Recommend me a static pressure fan...
28 Aug 2006
I have a Corsair H115i Pro.
I currently use 2x Corsair ML140 fans on it.
Are there any better PWM SP 140 fans, or, are the ML140's still fine?
Thanks.
The ML actually generate very high pressure at full speed -something like 50% more than the equivalent Noctua - but of course the Corsair are much faster - if you dare take them up that high! My guess here is they just aren't running up anything anywhere near full speed. You could write your own fan profile in iCEU?
ML fans are pretty decent for pushing a lot of air through rads.
are you after peace and quiet or out right cooling? If you want quietness then Arctic P14 is your go to. Otherwise stick with your ML and get them going a bit higher RPM. If you want really a lot of air - noctua industrial fans shifts a lot of air but noisy tho.
I can't believe you could get much quieter than the standard ML fans on the H115i Pro. They only spin up to 1050 RPM. I can't even hear it above my case fans
