Recommend me a surround sound system!
or rather sevenoaks, every richer sounds i have been too has limited selection and the salesguys are ..... (maybe a gross generalization but i have never seen a decent one and tried on quite a few occasions over the years - admitedly now i just don't bother)
Thanks for all the advice think I will check out the for sale section on av forums for some front speakers and maybe order the Denon amp tomo ;)
Now I need to compare the Denon 1611 to the Yamaha DSP-AX861SE the yamaha would be £200 compared to the Denon at £230 but which is better?
I've gone for a ONKYO TX-SR507 something I didn't look at untill now paid £170 for it and reviews look good I just hope it is good! Any thoughts!?
As long as it ticks the requirements you want then its fine. Would have gone for the 1611 for the 3d option in the future if it was me. Problem is the more options you see the harder the decision gets.:p
Does the onkyo upscale? Cant see it mentioned.
Would be more concerned bout the HD sound than the upscaling
At least you have made a quick decision. Took me ages - the more options I considered the more confused I got.
Enjoy your new toys
