Recommend me a Wireless Network Storage Device
12 Feb 2004
Manchester
hi guys
we have a 4 port wireless netgear router and all 4 ports are being used (i wish i bought a 8 port one now!)
anyway i would like to add a network storage device that holds say a 300Gb hard drive so all pcs in the house can view/store files on the hard drive, but it needs to be a wireless one.
i know netgear do a wired one http://netgear.co.uk/digital_home_sc101.php this looks ideal, if only we had a spare port on our router!
so can anyone recommend me one please?
thanks
Just buy a cheapy pc off the bay, then slap a 300gb hard drive in, assisted with a wireless network card?
i was just about to suggest that to my self lol thanks mate
thing is id rather not have a PC running 24/7 just so that we can share files, but maybe the cost of a wireless device that i need will be quite high, so getting a crappy pc to do the job will be cheaper!
what you recommend me installing for the job that freenas?
