Recommend me an OLED for gaming
21 May 2018
South Wales
Currently have an LG UltraGear 27GR95QL-B and it's an amazing monitor and still as fresh as the day I bought it however, recently moved house and updated the desk space... so, I'm looking for something much bigger perhaps 32" or bigger?
I've not shopped for PC stuff for awhile and wondered what you folks would recommend?
Firstly it is on sale for £500 down from £800
It has 240Hz
Its only 1440p but I dont think you need 4K on a display this size
Designed for gaming so has most of the latest gaming features like gsync and freesync
Has HDMI 2.1 and a good color range covering almost 100% of DCI-P3
It can tilt, pivot and adjust height which is a big plus in my view
It comes with a remote control
It has LG`s OLED care features
It has 240Hz
I think he wanted something bigger than 27" :P
Alienware AW3423DWF if you’re happy with ultrawide.
Got no issues with having an ultrawide now with the space I've got. :D
Currently looking at the 32GS95UE from LG and ASUS ROG Swift OLED PG32UCDP.
recently moved house and updated the desk space...so, I'm looking for something much bigger perhaps 32" or bigger?
LG OLED97G54LW ;) If you do buy this one am going be really jealous :D
AW3423DWF - comes on offer aroun the £470 mark every so often.
Had it a few months and it blows my previous ips screen out the water.
240Hz, remember 240Hz!
Honestly after 5 years of 120 or 144Hz I didn't see any difference moving to 240Hz, although maybe I'm attributing more of the visual improvement to Oled vs IPS instead of 144Hz vs 240.
To answer the question: LOVING my PG32UCDM. The glossy finish is fine for me, even with all the lights on in the room, although none of them are behind me. The only issue I'm dealing with is that it's super tricky to clean. I used to just attack my Dell IPS with some Method glass cleaner and a microfibre; I've been told that's not a good idea for glossy Oled so now I'm down to a microfibre wet with water only...and lots of time.
Distilled water or isopropyl 70%
if its oled I would say you should go for 4K. Refresh rate doesnt matter too much unless you're playing competitive. Saying that I dont consider anything under 120hz even worth getting in 2025 so thats really the minimum
