- 28 Jul 2009
Can someone recommend me some quality lcd screen wipes for my monitor?
Cheers
Cheers
Brilliant stuff that!Philips Screen Cleaning Gel.
just bought that , got one b4 but not from OC and they are great came with a little brush aswell (this one doesnt) which was awesome for cleaning the keyboard.Get some Iso Propyl Alcohol and just use that with a good soft cloth.
lifehacker said:Alcohol on your monitor can cause damage to the coating and dry out and crack the plastic.
howtocleanthings said:The magic bullet for safely removing fingerprints from LCD is an equal mixture of isopropyl rubbing alcohol and water (plain old tap will do, but distilled is less likely to leave streaks). You won’t need much of this solution to get your monitor completely clean, but make sure you measure accurately, because a solution that’s more than half alcohol may damage the computer screen
Microfibre cloth cheap at supermarket
