- 27 Oct 2005
So i've got 3x290x's and a 4.8ghz 3930k on one loop, with a d5 vario@2, and a copper car radiator, currently I have 2x akasa 230mm fans on it which are 19db and 27cfm@600rpm (poor i know)
With the hot weather my temps are creeping up slightly (the cards are hitting 50c and the cpu cores almost 60c)
I need some better fans to stick on there, I intend to make myself a shroud out of either mdf/fibreglass, and can fit 8x 140mm fans on it with 10mm spacing.
Whats the best out there? ideally I don't want to spend £25 a fan if i can help it
ta
ta
