planning on building an intel system with a e8400 processor
which motherboard should i go for? i want something relatively inexpensive that is reliable and stable , i dont need crossfire or sli and i wont be overclocking by much (if at all)
i also want some memory, i dont want anything fancy just something that will do the job but will be reliable and be fast enough to keep the system nice and punchy, i think 2gb should be enough - any recomendations?
Powersupplies... what kind of wattage will i need?
system will be e8400,2gb ram, 8800gt gfx card, 2 / 3 hard disks, dvd burner
will 500 watt do?
would like something on a budget that again is reliable but also quite(ish)
thanks in advance
will 500 watt do?
thanks in advance
