- 9 Apr 2006
I'm in need of a memory ugdrade. I currently have 2 x 512mb GeIL CL25-4-4DDR 400 and want to add another 2Gb.
I was looking at the OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 but not sure if it will be compatible with the Abit AN8 Sli motherboard? If it is then I'll probably buy that. If not then what else can you recommend?
