Recommend Midi Case under £100
20 Oct 2010
Hello,
A friend asked to help him change his old midi case to a new one with airflow.
Could i get some recommendations on what is good with a budget under £100?
The PC will sit inside an open desk cardboard from both ends so max dimensions for the case were W28cm, H50cm and L46cm.
Thank you.
