Recommend mp3 fm transmitter
25 Oct 2002
I'm after something like an itrip for listening to my iriver mp3 player in the car via FM. Firstly, are they any good and which one can you recommend which is good value for money?
JM
I got an istuff one. Absolutely useless. Terrible sound quality with low volume. Ended up getting a CD/Radio with line in which works fine!
That would be ideal but my motor (Saab) has one of those fitted cd players which you can't replace with a standard one. No doubt it could be replaced with one that has line in but it'll probably cost a bomb so FM is the only realistic option. I've done a bit of research and the AudiaX transmitters are well reviewed, albeit a long wait to get one. Might just pop into tesco direct tomorrow and see if they've got any of those itrip universal's in stock. If it's crap it's easy to return from there.
