Recommend new LED slim TV for wall 32"
1 Dec 2004
Glasgow, Scotland
Any recommendations folks?
Bought a 32" Samsung 4000 series and its awful - muddy, smeary on motion etc :(
Looking at LG and the higher up Samsungs 100Hz etc.
What do you think ?
To be honest you did buy the most basic LED of the range, at minimun you want to go for the C6000 range tbh, they should be quite cheap now as there end of line.
I didnt know better, read reviews and Amazon stuff which all seemed to sing its praises.
Went and got a 6000 at lunch time there from Currys - tested it in store with some sample AVIs and its far far better!
Agreed!
Just swapped them over, the good side of the 4 and 6 series looking identical :D
Also ran a cat5 cable through the wall to the new screen, wired that to my lan over power box and on firing up the 6000 series it spotted my Vuse torrent client on my netbook and offered up a load of AVI files to play right off the bat! Now I need to figure out how to pause and skip through streamed media.
Picture quality looks a million times better already so fingers crossed and touch wood it will pan out well.
