Recommend software to create bootable USB
20 Feb 2011
I need to create a bootable Windows USB an I can’t find any software that works! Can anyone recommend me a Mac app that can do the job?
TIA
Do you have an iso? Something like balenaEtcher may do what you want.
Yes, I’ve got the Windows 10 ISO. I’ll give Etcher a whirl again but that was one I’ve already tried. Maybe I’m missing something!
Something in the back of my mind is telling that Boot Camp Assistant will do it.
Have you tried Rufus? If you have the iso it will burn it to a usb stick and make it bootable.
Or if you want a bootable windows 10 stick use the Windows creation tool as it downloads, copies to the usb stick and then makes it bootable
I was going to say the same, but neither run on a Mac afaik
Yup. Seems it’s a bit of a nightmare if you’re Mac only. Might have to spin up a Linux VM for this job. Ridiculous.
ED209 - the Boot Camp setup doesn’t work on the latest MacOS but cheers anyway.
