- 18 Oct 2002
Evening all. I'm looking to change the PCI wireless card in my PC as it has absolutely atrocious reception (it's a broadcom wireless g for the record). I'm pretty sure it's the card as a laptop and iPhone seem to do fine.
Anyway I figured that I might as well get a card that can use the draft N standard because a) I might upgrade my router to N sometime in the future and b) I figured that with all those antennae they must have better reception.
So here's the question, can anyone recommend a card - it can be PCI or PCI express? Or on the other hand would I be better off just getting a presumably cheaper G card?
edit: If I did get a draft 2 N card what's the chances of it working happily with the final spec?
