I use a combination of Windows 10 pro and windows 10 Home between work and home and would need access to my files on the usb stick from both versions of Windows. I know Windows 10 Pro uses Bitlocker but do not know of anything that would allow me access to protected files using both versions (of Windows) unless, of course Bitlocker would allow access from both versions. Can anybody confirm this or provide an alternative recommendation? Thank you.
Edit: I would only need read access from home so I will try encrypting from work and reading from home after submitting the required key (to see if the files can still be read).
