Recommendation for iPads 2nd hand
24 Jan 2008
By Coffee cup...
Hi all.
I'm after an ipad pro 12.9in
As it doesn't have to be brand new, can you recommend any reliable places i could get one from ?
Yes, i will also Google it, but thought there are better places than others.
Thanks
Try Apple Store refurbs - 849 for an M1 12.9. That way you save a few quid but get a warranty, new shell and most importantly a new battery.
thanks
as need macbook pro , might use them as well as well.
just cant decide is pro m2 or i5 with more RAM and SSD....
Apple refurbs are the way to go. Sometimes you can find some great deals. Just bought a couple of iPad Pro‘s for me and the wife and I can’t fault them. Just like new and they come with 12 months Apple Care.
M2 will blow an i5 out of the water. Obviously depends on your use case but in terms of performance the M2 is the way to go.
thanks
I think we will pull the plug today.
will be used mostly for Logic Pro
will make easier to sell later when upgrading I think
