recommendation gpu water block
9 Jun 2011
UK
i have got one of these gpu EVGA GeForce GTX 780 Ti Superclocked and i just installed one off these XSPC RayStorm D5 RX360 V3 WaterCooling Kit and all as ok , now am want to get the gpu in the loop and i not sure which gpu water block to go for ,need an good one .i know i would need some more compression fitting's etc but i don't mind getting other make fittings as long they will fit the rad ,pump etc.would the pump/rad cope with the gpu water block ? as you can tell yes am new to the custom loop set up so bear with us
EK makes the best 780 ti blocks. Which one you choose is down to personal preference.
EK also makes cheap and cheerful compression fiittings. Just make sure to get the right size for your tubing.
Pump is fine with your loop. Rad will be pushing it. Which CPU are you cooling at the moment and is it overclocked?
I have the XSPC Full Cover Razor GTX Titan / 780 / 780Ti V2 Waterblock,I rate them awesome.
definitely get another rad in your system
