Recommendation to replace vp930b
12 Aug 2005
Singapore
Hey guys, i'm looking to upgrade to a 20/22" monitor to replace my VP930B
what do you guys recommend?
Using it for gaming+movies.
Thanks
well if you;'re happy enough with your VP930 then you could look at the scaled up version perhaps, the VP2030B? Also the same panel technology (and very similar to the VP930's) is used in the VX2025WM if you wanted a 20"WS model. They all offer very good all round performance which should be comparable to your current screen :)
hm.. the 20" vp series is out of my budget.. any others that are comparable with the vx20" ??
the Belinea 102035W uses the same 8ms AU Optronics P-MVA panel as the VX2025WM as well. Maybe worth a look? No other 4:3 models really using the AUO panel
hmm regarding the VX, the height is not adjustable right?
i'm currently using megaworks550, the front sate is kinda tall.. so wonder if i could still put it right under the panel?
wdEvA said:
hey guys, any comments on the VS 22"??
It's TN, as are all the 22" screens currently available, so the viewing angles won't be as good as your VP930. As well as the VX2025, the Dell 2007WFP is worth looking into, depending on budget.
