Hi there,
I bought my current pc 4 years ago (Feb 2009) for about £630, here are the specs:
Intel core 2 quad Q9650 3ghz cpu
ASUS P5QL motherboard
4 GB OCZ Platinum 1066mhz DDR2 (ocz2n10662gk)
Arctic freezer pro 7 (I think) heatsink
EZCool 550w power supply
Nvidia 9500GT graphics card
X-clio 3060 case
still only running windows XP 32 bit
obviously compared to stuff nowadays this is a bit of a dinosaur.
I've had a few issues with games crashing in the last six months on games it never used to like civilization V and footy manager 2013. All steam based, not sure if thats the problem.
I've also had a message on boot up saying the cpu fan is not working press enter to continue. this doesnt happen that often but when it does the fan isnt on but when I press enter it bursts into life!!! So I dont know if it needs replacing or not? Maybe this is causing the system to crash.
I want to upgrade to windows 8 but dont want to lose all the stuff on the hard disk, any recommendations?
also the giant fan (360mm) on the side of the x-clio case seems to have stopped working a few years ago and want to fix it as i think increased temps maybe one thing possibly causing my computer to crash even when playing low end games like football manager 2013. (I dont really play high end games)
I know the graphics card could use an upgrade as it was never great when I bought it. I've seen a few highly recommended like the GTX460 or AMD HD 6870 as an older option and people say they can get them for £50-60. So far i've only found refurbed ones for about £75 for the GTX460 and new £120 for the 6870. Really I'd only like to spend about £50-70 on another graphics card but looking around it looks like for something thats not gonna be obsolete in a few months like my current graphics card i'll need to spend £85-135 just for a decent budget card. I quite like the look of the nvidia GTX650ti for about £95 (thats the cheapest i've found) but the one most websites seem to be rating highly is the HD7850 saying they can get it for £120. cheapest ive seen it is £135. This may sound strange but I heard somewhere once upon a time that if you uprade from a Nvidia to a Radeon it causes problems? is this a myth? I'm sure loads of you on here have probably done this and could tell me. Thats one reason Im not sure whether to go with the AMD cards that seem better value at low to mid range cards.
Lastly does anyone know where you can pick up cheap priced DDR 2 ram from as I'd like to upgrade mine to 8GB when I hopefully get Windows 8 64 bit.
Sorry for the long post,
Any help appreciated.
X-clio 3060 case
BTW, for install progress you can change MyDosuments' folder name to MyDocuments2 and then copy this over "new" MyDocuments, just in case.
