Recommendations for a 1440p 27" HDR gaming monitor
I would recommend either the dell aw2725df or Samsung G60sd, depends on if you like matte or glossy. I had the dell before I upgraded to the 32 inch version. Think the Samsung is cheaper just now though.
I had the same question, so I will hop in on this thread if nobody objects.
I don't have space for two 27" monitors just now, so will need to use one monitor for desktop work as well as play, any idea what screen burn issues are like with the third gen panels?
Also, any love for the MSI MPG 271QRX? look to be fairly well regarded on the web.
I have been using the Alienware AW2725DF and have had no issues with it. Are you wanting to go with an oled ?
OLED seems to be the best for gaming and watching video, so do I want one? yes. Do I game enough to warrant it? yes. Do I do enough desktop work to potentially cause issues? unfortunately also yes.
So, while I am tempted to get one, I'd rather not be messing around with task bar settings etc. to prevent screen burn issues.
The Alienware aw2723df is a nice IPS monitor then if you don’t want to go OLED.
27”, 1440p, 240htz with a 280htz overlock mode.
They had brilliant Black Friday deals on them last year which stacked with corporate discount codes. It was about £550 rrp last year and I grabbed one for £300 ish on Black Friday by stacking the two discounts.
I managed to blag an AOC q27g3xmn for very little money.
If I don't get on with it, it was cheap enough to pass to my grand-daughter without grumbling :cry:
Honestly, cheap monitors have gotten amazing in the past few years.
The dell g2724d that my other half has is brilliant for the money and was about £160 iirc
Use rtings to get a good idea of how good a monitor is coupled with YouTube reviews
Subjectively, it's fine.
I have had faster panels, but the HDR performance is great for the money.
I find the worst aspect of its VA panel to be the viewing angles, but on my desk that's not really an issue anyway.
