Recommendations for a 22 inch
24 May 2010
Hey all :)
So m buying a new rig and want to get a 22 LCD
I want it full HD (1080) but the problem is that i can't find any good ones.
So can u plz guide me to any good ones. My budget is $220.
Also, if there isn't any good ones, or u think that its not much of a difference, then can u guide me to the 1050 good ones :)!
(its better if it has a viewing angle of 170 :) )
Thanks ;)
Is your budget really in $ or £?
U2211H or U2311HA - A little over budget but they should be sold cheaper in a couple of months when everywhere has stock.
2209WA - A little cheaper again, it has a res of 1680 x 1050 though. Should be able to find it for a little over ~£200.
