Hi all
My current desktop is getting a bit long in the tooth, it's an athlon II x2 250 with 4Gb RAM and it's starting to grind a bit when photo editing, part of which I suspect it just the W7 Pro install getting a bit bloated and partly the hardware getting a bit dated.
I principally use GIMP but I'll perhaps be going with either PS Elements or Lightroom in near future - but unlikely to be PSP given the online-only model. Images are bog-standard DSLR DNG RAW files, if this makes any odds.
I'd appreciate advice on what I could do for around £250 to £300 that would freshen it all up a bit.
I assume the usual board, processor and RAM upgrade would be in order, and I'd appreciate advice on what to get within the budget and in light of what I could recycle from my old machine.
It's got a Radeon 5570 with 1Gb RAM on PCI-e that I would plan on using, unless there's a compelling reason to change - it's not going to be used for heavy gaming.
I've bought a microserver so I only keep working files on the machine, which suggests it might be worth going for a small SSD. Otherwise a bog-standard SATA Samsung 500Gb drive will be reformatted and go in.
Optical drive and bog-standard case and all peripherals can be reused, although I'm toying with the idea of getting a new monitor as my samsung 19" is a bit restricting - that'll be a separate budget, although advice on a decent monitor appreciated as an aside - I'm not that clued up on cost vs quality trade-off so haven't fixed a budget for a new monitor yet.
I can get a copy of W7 through wife's work, so no need to factor that in. I listen to Last.fm when working through a £40 set of 2+1 logitech speakers, so no real need for superb multi-speaker audio.
I'd also perhaps need a new power supply as the current is from a Asus barebones of slightly dubious provenance and quality.
If anyone could give me a start towards the sort of things I should be considering, that would be much appreciated.
Cheers
Matt
eta: Apols if this is in wrong forum, there seem to be a lot of requests for advice in this one?
Cheers
Matt
