Am in need a good multi-platform steering wheel with strong force feedback, will be used with PS3, Xbox 360 and PC. Any recommendations? good clamping small footprint would be ideal.
Budget?
I would say the Logitech G25 but it wont work with the xbox.
Infact i think you will struggle to get a wheel other than the MS wheel to have decent/any support on the 360.
Well you're out of luck with the 360 as that only supports the official microsoft wheel.
For PS3 and PC i would recommend the Driving Force Pro (£60) or the Logitech G25 (£140). They're both excellent but obviously their quality is reflected in the price.
Only reason I put the xbox 360 in there was because I am hoping that theres another game besides gran turismo 5 and dirt on PC that will be played and loved forza 2 till my disc died.
