- 9 Oct 2007
Hi there,
I'm hoping you can help with a product recommendation.
I'm looking at buying the following combination of hardware.
Gigabyte GA-P55M-UD2 motherboard
Intel Core i5 750 processor
4Gb Corsair PC3-1066C9 1333mhz DDR3 memory.
This PC is going to be in our main living room, so I'm looking for the best options to keep it running as quietly as possible.
Can you please recommend a CPU cooler and PSU (600w minimum) that will enable this to ru as quietly as it can?
Also, are you able to recommend a case for this system? I was looking at the Coolermaster Elite 330, but I understand they can be quite noisy also.
Thanks,
Rob
Thanks,
Rob
