Recommendations for MBP 13 skin
28 Sep 2004
London
My girlfriend just bought a new MBP 13 and is looking specifically for a case that opens with the laptop itself, so it's always protected, but many of those available seem to require you to take the laptop out to use it.
Can anyone name a case or sleeve that might be what she's after?
Thanks
Hmmm I'd be dubious about using a laptop inside a case 24/7.
These things run hot as it is, so you'd likely run in to heat issues :(
That said, check out some reviews.. there are bound to be manufacturers that sell cases that don't intrude on airflow.
