Recommendations for USB-C Hub for 2022 13" M2 Macbook Pro - dual/triple monitor setup
4 Jul 2004
LDN
Hi everyone, I purchased a 13" MacBook Pro in July 22 while on holiday in America (it has the touchbar). I understand I can only run 1 monitor using one of the USB-C ports. I do have 2x27" 1440p monitors on my PC Setup that I would like to use with the MacBook if possible, with a view to possibly replacing the PC with the MacBook and run parallels with it in the future.
Are there any hubs that can be plugged into a USB-C port ont he Macbook that can give me a dual/triple monitor setup, or a way I can just use both monitors and not the MacBook's display. Any suggestions on how this could be done would be very welcome! thanks in advance
