Recommendations on a PSU
6 Jan 2008
Hi Guys
I was wondering what PSU would I need for the following setup and I don’t think I will over clock it either. Can anyone recommend a good PSU to buy too?
Intel Q6600
Nvidia 9800GTX
4 Gig DDR2
2 Hard Drives (RAID)
Thanks,
you shouldnt need too many Watts 4-500 will do, decent makes are Corsair, Zalman, Enermax, Coolermaster. Modular allows you to only attach cables you need, so you dont have any spares cluttering up the space inside yor case, but this costs a premium. Any of the above makes in that wattage range or above will do you fine
I personally would recommend any of the PC Power & Cooling PSU's at here.
Never heard a bad word about any of their products, i recently got the 750w model and its running really smooth, plus getting a model at that size will future proof your rig for further upgrades..
