Recommended Case For This Specifications
18 Mar 2006
Hello guys, looking for a reasonable good quality priced case for a new build these are the specifications:
Intel Core 2 Duo E6400 2.13GHz.
2GB Corsair XMS2 Dominators PC2-6400C4D.
BFG nVidia nForce 680i SLi Motheroboard.
BFG nVidia GeForce 8800GTS 640MB Graphics Card.
What you guys recommend.
Thats what im talking about, along with the side window in black would look smart is there any reviews so i can see the whole case inside and out. Keep those recommendations coming looking good so far.
That's the best of the best list for your budget I'd say. Mirage is a bit more, but it is a great case, and worth that bit extra IMO. ANtec 900 would be bottom of my list though - it's a far from perfect case, although looks pretty good.
- Lian Li PC7+ with side window = £91.57 incl delivery
- Akasa Mirage with side window = £124.46 incl delivery
- Antec 900 with side window = £78.65 incl delivery
The Akasa ZEN is also a smart little case. Very cheap too. Not sure you can get a window for it though. The Antec NSK6500 and SLK3800BUK don't get much of a mention here, but both are good cases from what I hear. Again though, not sure you can get windows for them.
:D
Yup, by all accounts it's a great case. Depends what you're putting in there exactly, but I can't see that you'd have any problems with your spec. Just search for the many threads on this case and see what others experiences are with it. ;)
PC7+ is a complete bargain, the window is pricey so that makes it 'ok value'
Good cooling and lots of potential to hide cables, just search case central to see people being sceptical of the case then buying one and understanding instantly what the craze is about. :)
Good case.
